pappyky
Will not start…place time in any position and can hear timer running, but when I press the start button nothing happens…was working just fine the previous load…could it be that switch/pts relay ? WQould like advice before blindly ordering parts . Thanks
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LEC8858EQ0
See the attachment for the wiring diagram.
At the top of my list would be the thermal fuse (Item 7 in Section 3)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
