dryer would not start as if no power. checked plug and breaker at box and both okay. read on how to check switches and checked push start switch had ohms reading of 2. was going to check timer switch and did not know were to put tester leads. what should i check for next. had forum with magician59 with no results. kelly
Are you saying you checked all the things I suggested and still get no power; or my suggestions didn’t make any sense to you?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LEQ8858JQ1
Only way to ensure it has power is to use a meter
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Another high on the list item is the thermal fuse (Item 7 in Section 3.
Unplug the unit and the wire going to one side of the fuse.
Then measure the fuse with a meter, should be 0 ohms.
OR
Jiggery pokery method is:
Unplug the unit.
Short the two wires from the fuse together
Tape them so they cannot short to anything else.
Plug the unit in and give it a try.
If it is blown replace it ASAP as this is a critical safety device, burn your house down safety.
Also clean/check your vent system as this is the most common cause of this fuse blowing.
