dryer stopped short and now does nothing
The dryer was for approximately 10 minutes and just stopped and now there is no power . we have checked the house circuits and the power supply all seem to be in working order. Wcant do the diagnostic check because there is no power. The tests that we have done seem to indicate that the electronic control assembly or the touch pas needs to be replaced. both are fairly pricey. is there anything we might try first before replacing these parts
I cannot find any info on the given model number.
Tried here and at the Whirlpool site.
Please check it.
How do you know that the power is OK?
Did you measure it?
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
