all of a sudden there is no heat in my dryer were would you start to see what is wrong any suggestions would help me a lot really don’t have the money to get a new one right now
— Begin quote from angeldevil1998;762307
dryer will not heat, can you help me?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED4800XQ
See the attachment for the wiring diagram.
Could be a power problem.
The heating coil runs off of 240 volts but on this unit so does the timer motor.
Set the unit to a mid scale heat cycle.
Does the timer advance?
If yes then you have 240 volts so I would start by checking the heating coil.
Often you can see the break. If it looks OK then I would get a meter, see below.
If no then you probably have a power problem, see below.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
[COLOR="Blue"][SIZE="3"]Leadunham [/SIZE]
Unless your unit is the same model, please start you own thread using "Post New Topic".
Hijacking angeldevil1998 post will just confuse things.[/COLOR]
