Have Maytag centennial, will only run a few seconds gets very hot the shuts off. Have replaced the following thermostat, element,timer,start switch and motor after replacing timer which was the last part I tried I was shocked pretty good from just touching the cabinet. I really would like to get this thing going any help would be greatly appreciated. Thanks, cherish
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=medc400vw0
See the attachment for the tech sheet
Here is the install instructions.
https://www.maytag.com/digitalassets/MLPDF/Installation%20Instructions%20-%20W10300459.pdf
You may have two problems.
Is this unit a 3 wire or 4 wire hook up?
The unit should not be able to give you a shock if it is wired correctly.
Other than a static discharge like when you walk across a carpet and touch something that is grounded. Your description does not sound like this.
The case/frame must go live (120 volts) for it to shock you.
For this to happen either L1 or L2 has to touch the frame and the ground must not be connected properly.
If the ground was connected properly current would flow to the ground wire and your breaker would trip.
So the first thing to check is the wiring.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Unless you have some experience with electricity, this may best be left to a pro.
