Please Help Dryer will not dry
Ok I have aa whirpool gas dryer. When first starting the dryer the igniter glows and ignites the flame. After this intial lighting, it will only glow but will not re ignite flame. Most common issue was to replace the coils, So I did. Same issue new coils and it still will not ignite. Any suggestions?
Problem started about 6 weeks ago of not drying and I found the vent tube was clogged, so I cleaned lint all out and still same issue thats when I discovered gas was not igniting. Do not know if this helps on a suggestion. Money tight trying to save money instead of buying part after part. Any help is appreciated. Thank You in Advanced.
