please help
i am getting f-1code and beeping and the oven door is locked.i replaced the EOC but same thing happing,i removed the flat wire in the back the code and beeping is gone but cant open the oven door.
i need to know how to rest my temperture please it will only go to 260c on bake i think i push something when i was cleaning … and i nned to bake cornbread at 375:rolleyes:
— Begin quote from akdaoud;141215
Which wire did you remove? Where it goes?
Check the switches on the door motor/latch assembly.
— Begin quote from SHONN44;141244
What is the complete model number of the oven?
Gene.*
Here are your parts. Your model number seems to be short several digits.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DVL223
I would start by checking the power as the heater requires the full 240 volts.
The motor, light and timer only need 120 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
