Possible faulty cold control ?
After opening my refrig. door for 5 seconds,the compressor turned on.
It ran for approximately 5 minutes, then turned off.
The compressor fan started back up,then off.
I hear a clicking sound while fan is on,then the compresor turns back on.
It runs for 2 min. then turns off.
While the comp. fan was turning on/off, I turned the temp control thermostat down to a warmer setting and everything turns off.
Help please !
I would drop the control panel and let it hang on the wires. Tap on the cold control and defrost control, one of them might be intermitent.
If ok, I would next check the connector for the control panel, unplug it and plug back in, might have a bad pin.
Ok thanks, I’ll try that and let you know !
— Begin quote from richappy;791941
I dropped the control panel, tappped the cold control and the fan shut off.
I’ve done this on several occasions, sometimes not even dropping the control housing and actually tapping on the housing.This too, is shutting off the fan.
Does this indicate that the cold control is faulty ?
I would take the screws out of the cold control to isolate it. If it still shuts off when tapping it, that confirms a bad control.
— Begin quote from richappy;794586
What do you mean, when you mention "screws" ?
Remove the control from the control panel.
— Begin quote from richappy;794714
Sorry I haven’t responded sooner on this.
It was the cold control that was faulty, after testing it.
I have since replaced it .
Thanks for your help !
Bill
