Power, No Heat
Hello,
My wife just informed me our dryers out. I checked it, has power, turns, just No Heat. Suggestions? I was planning on replacing the Heating Element & Thermostat (if needed), but want to double check before ordering parts on monday.
I’m a norm. guy with basic electrical experiance, No Tech. I would appreciate any help. Have the get this fixed asap.:frowning:
Estate Dryer
MOD: TEDX640PQ0
Try turning the breaker all the way off then back on and then try the dryer again, if that doesn’t work then follow the instructions below.
If you have an ohm meter unplug the unit and remove the rear panel. Test the thermostats and the element for continuity. The part(s) without continutity will need replaced. Let us know what you find.
Nat
This is a picture of the thermal fuse kit. It sit on the housing of the element. Tom http://www.applianceeducator.com
