I recently had a power surge. Now the oven light works, but everything else is dead. Can you let me know which part would have been blown by a surge?
Thanks.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FEB398WECD
Here is a wiring diagram
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318046110.pdf
Not the best laid out wiring diagram but it will have to do.
Looks like the lights run on L1 to Neutral but the board runs on L2 to Neutral re the POWER BOARD TRANSFORMER. Also it may have a safety thermostat in line with it which may have blown.
First I would check that the unit is getting 240 volts at the plug.
Try turning the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
Thanks for your help, I will let you know!
