Problem With Water Dispenser
The Water Dispenser Is Not Working The Ice Maker And Ice Dispenser Is Working Fine On Both Crushed And Ice Only.
Remove the control board cover (#843 on the break down diagram) and unplug the J7 wire harness connector from the control board.
Check for 120VAC between the pins J7-3 (yellow) and J7-9 (orange) while the waters dispenser calls for water and the freezer door is closed.
Post the results.
Disconnect the water supply tube from the union connector (80 on the break down diagram) under the freezer door. To disconnect the tube, push in the white collar on the quick connector and pull the tube out.
Check if water will come out under pressure from the plastic tube while the dispenser calls for water.
If it will then the problem is a frozen water line inside the freezer door.
In order to fix this problem the freezer door has to be removed and taken apart.
Mom’s Dryer Drum Is Noisy- Sounds Like Upper Roller Is Shot! I Can’t Figure Out How To Open Front Panel…theres Two Clips Between Top Of Front Panel And Top. On My Old Whirlpool A Putty Knife Would Release These Clips- But Not On This Maytag. How Do I Get Inside To Get To Tub Rollers? I Took Small Access Panel Off On Lower Front, Looked Inside While Running- Lower Roller, Belt, Appeared To Be O.k. Mom Can’t Afford A New Dryer-thank You.
I need the bucket for the refridgerator door. In addition to the model number of GRH220-3B, the mfg number for this appliance (side by side ref/freezer), is P1168106WE.
Can you help me find the part so that I can order it?
Thanks very much.
This one says to call for availability.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GRH2203B/P1168106WE&productCategoryId=0165000&brandId=1813&modelName=SIDE-BY-SIDE-REFRIGERATOR/FREEZER&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=I2203558&backToLink=Return%20to%20Sub%20Components%20list
