Quiet Partner III "flashing normal light"
Whirlpool Quiet Partner III does not work. It will go through a drain cycle, then the normal light flashes and the unit becomes unresponsive, unless power is turned off and back on, just to restart the above process. One last thing- all the cycle led lights as well as the timer led remain faintly lit- as if there is some sort of short.
Could this be a control assembly issue?
