Quit working
Went to use dishwasher again after using just an hour or so earlier and nothing is working. I checked the power outlet in the wall and there is power there. After reading a few post on here replaced the latch switches with the new switches and wiring harness, still nothing. IM not too sure where to go from here, please help.
The reason I chose to replace the door switch kit first was one of the connections was burned out, see attached, only thing I saw that didnt look right.
Did you check for power at the electrical connection to the dishwasher?
Out of the wall, yes there is power, not sure how to check power at the actual unit, mechanical minded guy here, not really to versed on electricity!
Well I will see what I can do about that, either call a friend that knows what to touch and what not to touch, but the rates at which appliance repair callout will cost me is too mcuh for me to bitwe down on. If i am getting power to the unit what would you think would be the next thing to look at ?
Check the float inside the tub to make sure there isn’t a fork, spoon, gunk, etc. keeping it stuck in the up position.The next thing to check is the float switch, itself. Then see whether the door latch is activating the switches.
If you’re getting power all the way to (and through) the door switches, I would suspect either a touch pad or a control board.
BTW: I didn’t intend to insult you with my previous post. I just prefer to remind folks that safety is far more important than the conveniences of modern appliances.
Thank you for the suggestions, no insult taken, I just don’t want to spend $100 plus for someone to come and replace a $10 part, you know what I am saying. I am also appreciative of the warning on the electrical side of things, that is why i don’t like messing with it because I am un-educated in that side of things. Trust me i want to be safe too. Looking through here some more could it possibly be the thermal fuse, that and the door latch components seem to be a regular occurrence of problems for this model.
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU943PWKTO
Check out the thermal fuse Item 4 in Section 1.
It should be 0 ohms.
Unplug/remove power from the unit and check the fuse with a meter.
If it is blown be sure to use the new harness that comes with it.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Problem fixed…ended upi being the Thermal fuse was blown, thanks guys for the tips and suggestions to helping me repair my dishwasher
OK I have blown the fuse again, dishwasher dead in the water…
What could cause the fuse to keep blowing ?
It’s gotta be a short somewhere. Double-check the electric connections to the machine under the toe panel.
Is the dishwasher on a line by itself or are there other appliances on the line?
Perhaps something has been added lately.
Check the power at the dishwasher to be sure it is getting 120 volts or close to it.
can you tell where in the cycle it blew?
