Range burners won’t light by themselves, I have to use matches, but the clicking is still heard on each burner. Do I need to purchase new burners?
Here’s a breakdown of your unit http://www.appliancepartspros.com/partsearch/model.aspx?model_id=250054
Chances are the clicking is coming from the spark modules near the knobs, but the ignitors themselves may be out. I would check for loose or broken wire.
Nat
I have replaced the heating element but dryer still does not heat.
Ran it for 15 minutes but no heat???
Check to make sure you have 120v coming to each side of the connection block, then check the thermal fuse, then check the thermostats.
