RE:help water leak
Hello,
My washer is working fine only had to replace cogs @ top once,it is 7 years old, it just leaked wate under washer, as I am disbled I cannot pulled out to check. water started leaking when tub filled, I cleaned what i could, looking on the side I see Blackish water,just a little, I mostly wiped up mclear water, is there a gasket under agititator or under washer going into tub, I don"t suspect rust as the water was clear, I had just started putting water,and was just about to add detergent. Any assistance would be of help in the right direction would very much be appreciated, I know this is not a lot to go on, but I can not afford repairman, and i have trouble getting someone to help me.
Sincerely
gasmitty
