refridgerator door wont close
refridgerator door wont shut all the way unless you push on it and when you open freezer it pops open…once pushed shut will pop back open after a while…water is condensing inside the fridge all the time and i dont knwo what to do…the frige is only around 2 years old or less. cannot find the warranty papers on it…what do i do?
If the gasket is in good shape and mounted properly, duck tape the door shut till the gasket seats properly. Do this overnight, should be fine in the morning.
