My refrigerator and freezer are both warm. The compressor runs and fans are working. The coils are not frozen. Everything seem to be working fine. Possible low freon or defrost problem?
If the compressor is vibrating, but not cooling the evaporator, you have a bad compressor/ refrigerant leak.
Thanks richappy I will check for a leak not sure if it’s worth a compressor.
