Refrigerator/Freezer Warm Compressor Hot
Refrigerator/Freezer is Warm. Compressor is Hot. Compressor making a funny noise. Condenser fan is running. No frost on Coils or condenser. Have cleaned the condenser coils.
[SIZE=3]The start relay is most likely bad. Unplug the refrigerator, the start relay plugs into the side of the compressor. Remove it and shake it, if it rattles when you shake it, it is bad and needs replacing. http://www.appliance-repair-it.com/Refrigerator-repair.html[/SIZE]
[SIZE=3]What kind of funny noise is the compressor making? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Is the compressor running? [/SIZE]
[SIZE=3] [/SIZE]
The compressor is running. It is like a rattling sound
you might have an seal system problem.:confused:
can you take the evp cover off and check your frost patten
Sorry?? What is an EVP cover? The the frost pattern be obvious once the cover is taken off?
[SIZE=3]The cover off the back of the freezer. Once off you should see coils, there should be frost on the coils. Tell us if the frost is heavy or light and if it cover the entire coils or not. Alos does the fan in the freezer run?[/SIZE]
[SIZE=3]You have a sealed system problem such as bad compressor, short on gas, or clogged capillary tube. Any of which are major repair jobs. [/SIZE]
