Refrigerator - ice buildup on freezer wall. Not cooling on food side!
The regular side of frig is very warm and foods are beginning to spoil. The freezer side is cool enough to the point that I’ve moved all liquid items - juices and mild over to it. It keeps them cool, but does not freeze them. There’s ice buildup on walls. Has stopped making ice in the ice-maker.
Note: it was doing the same thing about two weeks ago. I unplugged it overnight and did thorough cleanup. When re connected, everything worked just fine as they should. But then this week, it’s gone back to the same problems. And with money issues as they are right now, trying to decide if this is an easy fix, or would I need to have to buy a new one, something I’m really not looking forward to?
Help! and thanks…
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX22ZPDAWW
Sounds like you may have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 4) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
