Refrigerator making noise
Hello,
I’m hoping that I may get some suggestions here on my noisy refrigerator. :slight_smile:
I have a GE side-by-side with ice maker and water dispenser that is 18 years old. I’ve never had a lick of problems with it until I cleaned all of the lint, etc., from under the darn thing this week. (I should have left the dirt there. :smiley: )
I am now getting a kind of loud rattle or a very large cat purring sound which is then followed by a chirp. LOL This happens every few seconds when the fridge is running and it is getting to the point of hammer time.
I’m thinking compressor, but now I’m not sure. Any suggestions?
Thank you for your time and the opportunity to troubleshoot. :slight_smile:
richappy said:
I have fixed a few of these, it’s probably your compressor. Remove back panel and verify noise from the compressor. Remove compressor mount clips and tilt the compressor till the noise stops. One of the compressor internal support springs is now weak and tilting keeps the compressor away from hitting the housing. Now just shim it up with something like a large rubber gromet.
Thanks, indeed - I has this same problem, and this seems to have done the trick.
Given that this indicates a problem in the compressor, should we consider this a solution that buys us a bit of quiet time, but continue shopping for a new fridge, or can the compressor go on like this indefinitely? The fridge is 14 years old, so I am inclined to keep shopping.
As long as it will not rattle all the time, the compressor should be ok.
Great - thanks again!
[SIZE=3][FONT=Calibri","sans-serif][SIZE=3][FONT=Verdana","sans-serif][/SIZE][/FONT][/FONT][/SIZE]
[SIZE=3][FONT=Calibri","sans-serif][SIZE=3][FONT=Verdana","sans-serif][SIZE=3][FONT=Courier New][SIZE=3]I have a built-in KitchenAid/WhirlpoolKSSS48QJX00 refrigerator that was 2 days over the 12 year warranty that stoppedcooling. KitchenAid graciously covered theparts. The service people replaced thecompressor, evaporator and dryer. Whenthey replaced the parts, they found a corroded hole in the back of therefrigerator where the tubing runs from the bottom to the top. The refrigeratorwas cooling nicely, but developed a strange noise, like a gurgle. The noise isn’t constant and is now like arubbing. It comes and goes, but also ispresent after the cooling system stops, like a fan rubbing. I had the service man back and he couldn’tfind anything. He said that it could bethe coolant flowing through the system. Heasked me to record the noise, but I couldn’t record or even use a phone totransmit the sound to my wife. I got abearing stethoscope that mechanics use to trace a noise or check bearings. Ichecked the compressor, the input and output tubes, the condenser coil in the upperunit. The noise is detected on the backof the refrigerator, behind the evaporator, closest to where the tube comesout. The noise can be heard inside thefreezer. I took the cover off the evaporatorand fan and put a switch on the fan to see if that was somehow the problem, butit wasn’t. But the noise inside thefreezer was gone with the cover in place, but not screwed in place! I finally traced the loudest noise to the toptube of the evaporator just before it goes out the freezer to the back. Is this a coolant noise? Or something in the way the repair wasdone? The way the evaporator coil andtubing was installed? The way the tubingwas routed? The noise is getting louderand the cooling is less. The bottom ofthe freezer was usually at 1°F after the repair, but now the lowest is 9°F andmany times in the 12-16°F.[/SIZE][/SIZE]
[SIZE=3]
[SIZE=3]Any suggestions would be appreciated.[/SIZE]
[/SIZE]
[/FONT]
[/SIZE]
[SIZE=3][SIZE=3].[/SIZE][/SIZE]
[SIZE=3]
[/SIZE]
[/FONT]
[/FONT]
[/SIZE]
They did a poor job sucking out all the non-compresables, not good for the compressor. Best to call them back soon, or you will loose the compressor. The core of the evaporator should chill down to near -20 degrees, if not, that is your evidence.
— Begin quote from richappy;676068
I sure appreciate this entire thread, just wanted to say THANK YOU :slight_smile: It’s so wonderful to be able to actually fix these things myself, and it’s really nice of you all to give advice like this that helps all of us so much and saves us money. Thank you again!
