refrigerator repair
I have a 36" ge monogram and the lights in the freezer are not working. I changed the bulbs, checked the bulb housing and there is no power going to the housing. I also checked the switch for the freezer, I jumped the wires and the fan works properly but still no lights.Any ideas?
there is a light sensor inside the freezer compartment that went bad it senses if the bulb may have gotten to hot.
do you know where this sensor is located in the freezer
yes, its located under the light panel where the bulbs are remove screws from panel should be there. two wire disc
