Remove & Replace Motor
Need to know how to remove and replace motor in dryers.
couple of items. first the correct forum would be for dryers. second your model # dosent come up. please re-check your model # and repost in the correct forum.
I think I should next test the thermal fuse. Can anyone look at the manual ( http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204377829.pdf ) and tell me how to get to it. I’m a novice and I don’t know whether if it’s in the front or back! I guess you have to remove the blower housing . I just bought a multi-tester. I guess I should just test whether the fuse has continuity or not ( If I figure how to get to it! :confused: ).
