remove front panel
the tub has come loose, how do i remove the front panel to check if there is a loose nut.
Remove the front panel by pushing a locking clip (#373 on the [B]diagram[/B]) on each side between the top panel and upper edge of the front panel with a putty knife and pulling the top of the front panel toward yourself.
Thank you very much
My fridge stopped working. Found out that my Adaptive Defrost Board was bad. I bought a replacement board and plugged it in. I plugged in the outlet and the fridge started working. When I checked on the fridge 1/2 hour later, it stopped. The new Adaptive Defrost Board was burned on the same spot as the old board.
I got another board, but don’t want to plug it in yet. Any ideas as to what I should check next. Any help is appreciated.
I would check the defrost heater and the defrost thermostat.
Thanks. What should I look for in these two areas?
— Begin quote from ApplianceJunk;325842
I can’t seem to find these two items… help.
They are located in the freezer.
— Begin quote from ApplianceJunk;326108
lol. thanks, I knew that. I appreciate the help. I’m a novice… I don’t think I’ll be going any further. time to call in the calvery.
