how do i remove the drive hub from the plastic agitator part. It seems to be attached. heard squeaking other day and found that it wasn’t fully agitating. took agitator off and found these cracks in what appears to be the drive hub although i’m not exactly sure I also noticed some wear on the transmission shaft and wondering if i have to replace anything there as well or if maybe that’s the cause of the problem. thanks for any and all help.
Related topics
Agitator failing on GE model WSM2700DAWWW | 1 | 2950 | August 30, 2012 | |
GE Washer won't agitate properly and can't figure out which part to get. | 2 | 2007 | January 26, 2010 | |
how do I remove the bottom drive gear from the agitator , | 1 | 382 | October 3, 2015 | |
GE washer (stacked laundry unit WSM2700) does not agitate, broken agitator driver hub | 2 | 2398 | November 21, 2013 | |
Stuck agitator coupling | 0 | 5013 | November 6, 2007 |
