Removing tub from Maytag washer
Hello
I have a Maytag top loading washer model LAT9416AAE.
The tub is not spinning on the spin cycle but agitates fine.
I am trying to access the tub bearing. I have removed the inner tub and am now trying to remove a cone shaped thing. I have removed the torx set screw that is there.
How does the cone thing remove? I don’t want to bang on it too much. Does it screw off? If so right or left hand threads? Pry off?
And if you want to, you can tell me what else to do to get to the bearing and see if it’s bad.
Thank you very much!
