Is there a manual, diagram online or can anyone tell me how to remove the water/ice cover on the front of the door so I can replace a broken water actuator? The refrigerator I have is a Frigidaire Model #FRS23KR4A Thanks !
I also replaced a broken water actuator recently. Although I got the water actuator replaced with relative ease my ice maker won’t stop running now any I can’t get the water to work at all. The ribbon connector did come off of the cover, but the other end stayed attached. Everytime I go to re-attach the connector the ice begins to go and the water won’t work. Any ideas on what occured b/c I think it hs something to do with the ribbon connector falling off.
Have you had any luck so far? i have the exact same issue. Temporarily i have put the panel back on, but the ribbon connector is not attached inside as every time i had it in the water lever is dead and the ice won’t stop. so as of right now nothing in the panel works…
— Begin quote from Always Something;161157
NO, I have had no luck yet. I did order a new ribbon to see if that is the problem. If this doesn’t work I guess I will break down and call someone to come out and fix it.
Did you find a fix? I am having the same problem
— Begin quote from jasmine31577;157541
I am having this same issue as above and numerous other threads I’ve seen but can’t seem to locate a thread on what it’s caused by or the final fix. It seems like there might be a reset or something causing the issue. Or is the ribbon bad? Any help would be appreciated. My model is
[SIZE=5]FRS6L9EESS1. [/SIZE]
Did anyone figure out what the problem was? We just replaced our water paddle and when we put back, the water does not work and the ice runs constantly… Before I order a new board would love to know what it is
Hello, I am having the same issues as everyone else, but with the water instead of the ice. After I replaced the actuator and reconnected the wiring, the water stays running and the ice does not work. Did anyone find a solution? I disconnected the fridge and connected it again to see if it would reset, but the problem was not resolved. Any suggestions?
