Replace GE wall oven control board
The oven woks for 15 or 20 minutes and then gives either an F3 or F5 fault code. I have replaced the temperature sensor and that did not solve the problem. This is a wall mounted single oven, what do I have to do to replace the electronic control? Thanks in advance for any help you can offer.
