Replace water tube from valave inlet to icemaker
The water supply tube to the icemaker on our KitchenAid KSCS251 referigerator dried out and cracked at the bottom near the valve causing a water leak. I want to replace this tube. The tube runs up the back of the refer and enters the freezer compartment at the top of the unit. I can also see the drain part of the tube in the icemaker, but the rest of the tube runs along the top of the freezer behind the top plastic panel. How can I replace this water tube?
Thanks, Chuck
