Replace
I am replacing the transmission brake assembly on this GE Profile washer. I have the tub/drive assembly removed from the machine, but cannot remove the agitator to allow me to remove the spin basket from the tub.
Any suggestions? When I remove the cap from the fabric softener there is a semi-transparent cap below it that I cannot seem to move and am trying to avoid breaking.
Good luck with that tub nut, you may want to post this removal as a separate problem if you have trouble, I believe it is a left hand thread.
Thanks, that worked… Got the tub nut with a 8" pipe wrench… All back together and running fine.
