Bake element burned in two. Replaced. No broil or bake. SUrface elemts work fine. Continuity test on bake element is 21.5 ohms. Broil element is 35.5 ohms, I have a picture of the schematic and have taken numerous continuity measurements. The selector switch seems to be working fine.
Alll wires/connectors are in good shape.
Need help determining if it might be the thermostat or clock/timer.
I’m not sure how to evaluate the continuity tests fromes these.
Thank you in advance
Scott
