I replaced the Broil Element and the Sensor in this oven. After replacing both items the the system would not regulate the heat. The Broil element would stay hot. I then shut power off to the oven at the breaker for about 10 minutes and tried again. After the oven went through the preheat I received Error code E2 F3. This shows bad sensor, just replaced sensor, what gives?? Am I missing a step in the process??
Check you connections to the sensor.
Nat
Is there a way to test the sensor? I checked the connection and it all seems to be good.
It should be listed on the tech sheet, usually inside the control panel.
Nat
In case you do not have it here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
Thanks, that helps except for now the door is locked and it is closed and I cant get it open. This is great for baking at Christmas…
I have read some reviews on this oven and learned that this is a common recurring problem. This is going to have a total cost of about 400.00 to repair all that is bad. Is it really worth the expense if this is something that is likely to happen again?? What are the most recommended products with the least amount of problems???
