Hi:
I replaced the lower burner in the bottom oven and it still does not heat up.
The broiler burner on top of the lower over works but the lower oven wont go over about 235 degrees because the bottom burner won’t work even though I replaced it.
The upper over is a short oven, good for pizzas, bread etc, and it works just fine, plus all the burners on the cook top part work too.
The only thing that is a problem is the bottom burner. When I replaced it, I forgot to flip the breaker, and some sparks flew, but everything still worked like before except the new burner does not work.
Any thoughts on what the problem could be? It’s not worked for a 2-3 years so I guess it’s time I fixed it!!
Thank you,
Paul
