The top burner works fine. The bottom burner has no heat. The controls are all normal.
I checked the power source- all is fine.
The element itself looks fine- no breaks or white spots. I pulled it out to see if it had come disconnected. It is connected fine.
Do you think it’s the element or the thermal switch- or something else?
