I’ve tried calling, but since the parts are discontinued, the only recommendation was a universal knob kit that doesn’t match at all. Our finish is stainless steel and the original 42mm knobs look like this:
https://www.rcappliancepartsimages.com/dbImages/i/00003283/Control-Knob-00411364-00987970.jpg
I’m looking for something that will look factory even though it isn’t. I’ve seen some bosch knobs that seem like they will work, but I don’t know about sizing of the stem. If anyone has run into this issue and has any suggestions, I’d love to hear them. I plan to rebuild the knobs later when I have time using a filler to just make the entire rear of the knob solid, but I need something in the meantime to get by and/or in case they can’t be repaired.
Thank you for any suggestions.
