I have a RF374PXDW1 Whirlpool electric range in perfect condition. Started throwing codes so had a tech look at it. He says is just the thermal fuse (part# 3187848). I can’t find one anywhere. Are these things rated for temp or what? Seems like there should be another fuse that could substitute if the heat rating was the same. Any suggestions?
We’ve tried everything. The fuse reads open. I found a fuse on ******** yesterday. If that doesn’t work I’m not going to waste money on a board. It’s 16 years old and will be scrap metal at that point.
