replacing a baking heater element
The bottom element in my oven isn’t coming on…I think I need to replace bake Part Number: AP2826718 Manufacturer’s Number: 367646 made by BOSCH ,
Is it easy to do myself?
regards, Alan
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RED30VRS
Usually replacing the element is pretty straight forward.
Unplug or remove power to the unit.
This is very important because even with the element turned off it still has 120 volts on one side of the element.
Undo the screw/s holding the element to the back of the oven cavity.
Carefully/gently pull the element forward so you can disconnect the wires from the element.
It is a good idea to clip something onto the wires (clothespin etc.) so they do not disappear into the back of the unit before you can get the new element installed.
