I am trying to replace an old 30yr GE electric cooktop with a Jenn-Air (used)…The opening is 30" X 21"…the new cooktop’s dimensions are 30" x 21.5". How can I compensate for the needed 1 or 2 inches to mount it? The counter is ceramic tile. Is there some type of gasket that is sold? The old one has a metal frame type thing around it…don’t thing I can use it to hold the new one. Thanks.
Your best bet would be to mount a 2x4 (or 1x4’s one on each side) on one side of the opening and find some tile to cover it. It wouldn’t take much tile to do that job and tile is easy to install. If you were close enough I’d give you the tile…lol…have a bunch I bought at an auction a few years ago.
nat
Yes mount it underneath the opening, then use a filler stip of wood to bring it up to level (if installing tile bring to level with allowance for appropriate tile/covering.
Nat
