Replacing front air duct assembly on GE dryer
Good day!
I have removed the cover, removed screws holding front panel assembly to the cabinet and now can see the front air duct assembly which is attached to the front panel.
How to I seperate the front air duct assembly from the front panel? I see only one screw at the top that holds the light bulb in place. In addition, how does it seperate from the upper aspect of the air duct assembly. I only ordered the lower aspect as that is the piece that is broken, although I decided to order new bearings for the upper assembly as mine were looking worn and for a few extra dollars and the machine being apart already. Like I said, the only issues I’m running into is how I get the front air duct assembly apart from the upper asect and the front panel.
Thank you so much for your help! My budget appreciates DIY help sites like this. :smiley:
