Where do i have the Instructions to replace the Interior Glass of the Oven Door.
Remove the door and put it on a flat surface with the front of the door facing down. Make sure the door handle is not in the way.
Remove all screws holding the inner door liner and put it aside. You have access to the inner door glass.
You can find the complete instructions how to remove the door in the [AP2929117](http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208300772.pdf"]"Use and Care"[/URL] manual (page 13).
- The part number for the inner door glass is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=2929117&&model_id=264798&diagram_id=121980)
Here are the break down diagrams for the Whirlpool range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=121980&&model_id=264798
I have an Amana gas dryer. It does not appear to be compleating cycles. Sometimes it heats way to hot; other times it takes several alot of time to dry a load. Is the cycle therostat the problem?
