Replacing sump pump gasket
I’ve discovered a leak in our dishwasher. When I pulled the kick plate it appears that it is leaking around the sump pump. I’m guessing that I need to replace the sump pump gasket. Is that correct? If I’m on the right track, how do I go about replacing the gasket?
Any help would be appreciated.
