If I gently lower the lid the machine does not run. If I drop the lid from 6 or so inches and let it ‘slam’ the machine starts fine.
My sense is that a small adjustment may fix this. Can I do this without taking the machine apart?
Thanks,
Doug
Thanks,
Doug
[SIZE=3]The lid switch is wore out and needs replacing. If you don’t eventually it will not work at all. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]These pages should help [/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/washer-not-spinning.html
[SIZE=3][/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html
Thanks ApplianceMan.
