roper washer not spinning on spin cycle
not spinning out on spin cycle. i have crossed lid switch with wire and it was barely spinning. water is pumping out. i also changed the motor/gearbox coupling.thanks mark.
A bad clutch is typically the source of this problem. Take off the agitator then take off the motor as you did to replace the coupling. The transmission will now come out by removing three bolts, and you can replace the clutch.
http://www.appliancepartspros.com/part_details.aspx?part_id=3094537&rdr=%2Fpartsearch%2Fmodel.aspx%3Fmodel_id%3D5137183%26diagram_id%3D950590
Fantastic, glad that worked, and thanks for the update
You might want to put an amprobe on the power wire to the washer to make sure the motor is not drawing above 10 amps in spin. If it is, your motor might fail or just burn up.
