Roper top-load washer basket/tub won't spin
The washer works fine when washing, but will not spin in spin cycle. I ahve pulled the motor coupling and it looks to be in good shape. When I tilt the machine back, I can see the drive shaft is turning the drum below the brake drum. I’m guessing this is the clutch. So, I’m thinking my problem is somewhere above the clutch to the tub or the clutch itself. I also have a leaky water pump. That’s an easy one. Is there a drawing of how this thing is assembled somewhere I can get. I have not pulled the tub and agitator yet to check the spindle on the drive shaft or the drive block yet.
Probably a clutch issue (and check the brakes while you are in there).
Here is the part with the video of how to replace it.
AP3094537
and if you click on your model number you get taken to exploded views of your machine.
— Begin quote from sidfink43;759454
[part]AP3094537[/part]
thanks again for the advice, think im going to just buy another one. so many parts need replacing on this one it wouldnt be worth the time, effort, and money. Thanks
If you shop around you will find you can get this exact same machine for about $300 to $350.
Good luck.
