Roper / Whirlpool Gas Dryer No Heat - what next
Hello, I have been chasing trouble on this gas dryer for a while.
Gas dryer, no heat.
When I hit start on dryer the igniter glows nice bright orange for about 12 seconds, then goes out. No "foof" of gas, no fire. After a few minutes the igniter lights up again for about 10 to 12 seconds, and goes out.
I have metered the fuses/thermostats and all check OK.
Igniter and coils have been replaced already, new coils meter OK (as did the old ones).
Flame sensor seems to test OK, I have a short across the terminals, and I did remove it and tested with heat (near the tea kettle!), it opens up when it gets hot.
Any ideas other than another set of coils, or bad gas valve? Dryer sat for a year and another thread here said could be bad gas valve if it sat for a while.
Any ideas would be appreciated. Thanks in advance!
Paul
