Samsung dc code and Drum Shaking
Hi! I hope someone can help me. Our washer is a couple of years old and has started malfunctioning. It will begin the spin cycle, and spin smoothly on low speed, then around 12 minutes when it kicks into high spin, the drum seems to suddenly start shaking, bangs a few times, and stops spinning, restarting a few times and then throwing the dc code.
This will happen with every load, big or small, and even after I redistribute the clothes inside. I’ve tried:
-checking with a level, it is level on all sides
-putting thicker pads on the four sides outside the drum
-replacing the four washer dampers, making sure to use plenty of grease
I’m still having the problem. I’m at wit’s end and have no idea what could be causing the excess shaking of the drum during high spin.
Thank you for any help!
