Samsung error code E0 and stops
Dryer will run for less than 30 secs then stop with error code that is an E with the top line missing and 0 (E0). In the few seconds it will run the dryer gets hot inside the drum. Dryer vent is open and blowing alot of air out of it. I ohmed the heating element and it measured 10. I had continuity across the terminals of the high limit switch and the other thing (assume is the thermal cutoff) that is on the element housing. I didn’t test the thermistor or the other thing that is on the blower housing. It runs fine on "air fluff" where is no heat involved.
Looking online I have seen to replace the main board but I’m not sure that will fix my issue and I hate to drop $110 for a shot in the dark. Some people have posted they replaced it and their issue remained. Others say to replace the main board and if doesn’t fix it then replace the switches/buttons board. That’s another $75.
Anyone have any advice for this issue?
