Hi all,
I am having a problem with the spin cycle on this washer. It goes into an unbalance at about the 6 min. mark, but not everytime. I have checked the suspension rods and the hubs under the washplate and all appear to be ok. When i tipped it to check the bottom it appeared to still have some water in the outer tub (it doesnt sound like a lot). Could the problem be weak springs or maybe the secondary water pump. Is this pump supposed to pump the water back into the tub while in the spin cycle? I am stumped why it is doing this. It worked fine for three years and then until this.
Thanks for the help
It is on concrete and leveled perfectly.
Drier sounds like it wants to shut off. Makes a stop and go noise
Please post the full model number and we can probably give you some guidance.
