I just replaced the resevoir inside the refrigerator and ran a new line from the inlet valve and to the resevoir. I is getting water through the new line, but it is not disensing through the door. The lever inside the door is working and filling the resevoir but water is not getting through so I believe there is a clog between the resevoir and the union at the bottom that goes into the freezer door. I tried blowing through the lines and inside the freezer door and bottom I can hear are getting trough, but between the resevoir and bottom it seems to be completely clogged or something HELP!!!:eek:
Does this model have a filter that im not locating? Maybe its clogged? Nobody seems to list a filter for this modle.
