Our built in whirlpool oven has power but wont heat up. The digital time works and keeps time well. The controls seem to be fine but the oven wont heat up. Don’t know if it could be the heating element or something else.
If both Bake and Broil do not work then the problem most likely is a bad oven shut down thermal fuse on the back of the oven (#37 on the diagram). You probably used the self clean prior to the oven stopped heating?
- The thermal fuse AP3885687
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264481
I have the same issue. Power failure and codes, do not remember what the codes were.
Fan keeps running, bake element won’t glow red but gets hot.
Display does not show prebake or warm up count down like before.
HEAT light on display goes out too quickly where before it would stay on until oven was hot.
Turned breaker on and off.
Took out control board to check ribbon cable.
Display seems to work fine and read other posts but none indicated fan kept running.
Sounds like the problem is a bad oven control board.
- The control board AP3177932
Trying to replace relay (brown piece) and need to know which prong (1,2,3,4) to put 2 combined white wires from refrig which are on one female end and need to know which prong number to put it on. top left prong is 4(short prong) and top right 3, bottom left prong is 1 and bottom right is 2.)919-571-7901 thanks for your help[LEFT][COLOR=#000000]
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/407228-roper-relay.html#ixzz1kaKHT4gI
[/COLOR][/LEFT]
If you failed to take a picture, or make a diagram of the wiring and you wire the ptc device wrong, you will blow out your compressor! If you have the old ptc device and a meter, I can help.
