SLOOOOWWW Heat
Relays click on when oven turned on, No ERROR codes. Good power to oven, top oven works correct. Bottom (main) oven takes long time to heat, element doesn’t glow red. Power is good.
Broiler works, neither convection nor bake in lower heats past 200’F, relays click on but never heats up. Bad element in the lower?
Electronics are covered by 5 year warranty but not element I’m sure.
Thanks for the FORUM and the help.
